What about the front of the tablet?
What about the front screen . because my tablet's front part is cracked and has 2 hole in it one on the side of the tablet and one on in a crack part.
Questa è una buona domanda?
You're probably dealing with just a cracked screen, assuming the holes weren't caused by a severe puncture and just by a drop or something. Plug a USB cable into a computer, see if the computer recognizes it. If it does, problem solved: replace the LCD/Digi assembly and you're home free. If it doesn't, you may have a damaged logic board and should explore that along with alternative problems (bad charging cable, bad battery, bad charging port, etc.)
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 52
