Salta al contenuto principale
Repair and disassembly guides for Kenmore Microwaves.
Repeats 1234 error code on display screen
We had a severe storm which resulted in a power outage for about 24 hours. When the power went on, our microwave started to run though numbers on the display screen. 1 2 3 4. It runs through each number about 4 times until it stops on 1.
Update (07/24/2016)
It's a Kenmore model number 721.80032700.
Questa è una buona domanda?
Punteggio 0
4 Commenti
What microwave is it. Make and model number please
da
Thank you, I will try it.
da
That worked! Thank you for your help.
da
Glad I could help ;-)
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Sometimes shutting off the circuit breaker that the microwave oven is connected to for 30 seconds will clear the fault, error or function code; however, there are some cases when further service may be required.
http://products.geappliances.com/applian...
Punteggio 1
Aggiungi la tua risposta
Jackie Dobransky sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 321
