Salta al contenuto principale
Rilasciato il 19 settembre 2014, è la versione con schermo più grande (5.5") dell'iPhone 6.
1525 Domande Visualizza tutte
iPhone 6 plus screen does not Swipe properly
Okay so this issue seems to be pretty unique because i looked through all the questions here and I did not find anything but I work in a Phone repair place and I encounter this pretty often.
Iphone 6 lightly bent frame on the top right corner. The screen does not swipe sometimes. There are small thick lines only on the top of the screen (flickering). Once i put pressure on the frame on the top right corner screen seems to start work again when I let go this flickering starts again and screen has issues again.
I would really appreciate if someone can give me an answer on that!
*checked multiple screens, sure it is not long screw issue (no screws installed), encounter this on multiple phones, Apple used to replace those but nowadays the manufactured warranty is expired!
  • Thank You!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
This is a belated answer so hopefully it can be of use to folks who search for and find this question.
Touch Disease is a common failure on the iPhone 6 Plus.
At first, the phone will typically develop intermittent touch control failure. For some phones, a gray/white bar starts appearing at the top of the screen. Twisting and applying pressure in certain spots sometimes allows touch control to work for a short period of time, but eventually, the touch interface ceases to function entirely. This is colloquially known as Touch Disease. You can look at my profile for a link to a blog article on Touch Disease or search the web for more info.
Punteggio 3
Aggiungi la tua risposta
Chris sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 231
