Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3530 Domande Visualizza tutte
Flashlight not working after screen replacement
So, a friend brought me his iPhone 5s because he knows I like to play with this kind of stuff.
His phone had the screen shattered. So, I ordered a new one, and tried to follow the instructions but I had a few problems during the repair.
1st, There was four connectors under the bracket, 3 of them came from the display (I think they were, digitizer, camera and earpiece and lcd) and one that I dont know.
The one that I don't know where it comes from was accidentally disconnected with my prytool and I had a hardtime trying to get it into place.
I finally got it into place and could turn the phone on. Screen ok, digitizer ok, touch id ok, front camera ok, earpiece, proximity sensor, everything seemed ok.
1 day later he called me. His volume button is not working properly, he cant raise the volume, only lower. And the flashlight is also not working.
I must admit I forgot to test the flashlight, but the volume rocker I did, and it was working just fine.
What should I do now?
Questa è una buona domanda?
Punteggio 1
1 Commento:
The 4 cables are Camera, Digitizer, LCD and camera+earspeaker
da
Aggiungi un commento
1 Risposta
Hi,
The 4th connector was right above the other 3 connectors right ? then it was the camera flex. tell him to try his camera. Maybe you only damaged the few wires of the flashlight.
For the volume buttons, i don't know, you should check them
Punteggio 0
Aggiungi la tua risposta
henzpedro sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,761
