Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Can I fix touch ID by replacing the home button shield cable?
Hi,
So I've *successfully* replaced a water damaged screen on my iPhone 6, retaining the original home button, shield plate and home button cables. I now have a functional phone and home button but with no touch ID (yes I have tried a hard reset and re-seating all the connections).
I cannot see any damage, but it was difficult to pry up the original shield cable from the old screen and if any damage occurred I think it was probably there.
The touch ID was still working in the old assembly after the water damage.
I have read varying accounts of whether replacing the long home button shield cable can restore touch ID, or whether this is part of the logic board / home button set that must stay together.
Can anyone clarify? I ask in particular after seeing the iFixit disclaimer for the "iPhone 6 LCD Shield Plate with Sticker and Home Cable" part, stating "Please Note: Replacing the cable will cause the Touch ID sensor to stop working".
Thank you.
Questa è una buona domanda?
Punteggio 0
1 Commento
If it's basically this then there is no problem replacing it.
iPhone 6 Home Button Link Cable
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
No one can verify. We don't have your phone, not even a picture of the damage area. You have to try yourself.
However it is highly likely, since it still works in the old unit.
Punteggio 3
Hey Caitlin Corkhill,
Sadly if you replace the shield with the cable, it will stop the touch ID function.
Punteggio 0
3 Commenti:
No, just replacing the button itself causes this problem
da
He's talking about the cable on the shield, read better Tom and than reply.
da
I don't understand how a home button extension cable replacement would mean touch ID wont work.
da
Aggiungi la tua risposta
Caitlin Corkhill sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 148
