Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
Camera wont take pictures.
My iphone 6 camera wont take pictures I can open up the camera app and see that the camera is working but when i click to take a picture it does the normal picture taking animation but nothing is saved, its very weird because when i switch to video mode the camera can take a video and save it like normal, any ideas of whats wrong or what part i should replace thanks
Questa è una buona domanda?
Punteggio 3
4 Commenti
I replaced the camera and still the same problem also flash isnt working
da
i have the same problem but video won’t work for me either
da
my iphone 6 doesn't take a photo or a video.. when i go to camera it only become dark even if i place the capture button it still dark no photo or video, i need a help plzz
da
My phone does this too! It’s really confusing. I can take a picture and it’ll do the animation and stuff, but it just doesn’t appear in my camera roll! Even when I save something from the internet or screenshot something, it doesn’t appear in my camera roll. I wonder why it does this
da
Aggiungi un commento
8 Risposte
Risposta Più Utile
in my situation , both camera were not work , after change camera ic U2301 , all thing go ok , but photo not saved , the fix was so simple and easy , just change your time zone then back it to auto set from time setting , and thats all , camera now saved photo normally .
Punteggio 2
1 Commento:
Only to return what permission to take pictures of the same is not critical permission where do I go on my phone to get my phone better to take pictures help me
da
same problem here. no solution
Punteggio 1
I had this problem too but after rebooting my iPhone 7 twice the photos began saving again. Hope this helps
Punteggio 1
This doesn't require replacing anything, because you said it takes videos. Have you done a hard reset? Hold power button and home button until phone restarts
Punteggio 0
7 Commenti:
Just tried that it didnt work and I also noticed I can take panoramas and they save but snapchat doesnt take pictures only video
da
What version of IOS are you running?
da
I'm running the most recent version 9.3.3 I think it is
da
I would try updating the phone through the computer, most times when updated over the phone it can be a bit buggy
da
The flash also doesn't work
da
Mostra altri 2 commenti
I was told I need to have front and back camera replaced. When guy tested camera he said nothing wrong with cameras, what else can be the problem pls?
Punteggio 0
3 Commenti:
It worked!!!!!!!! Thanks!!!!
da
What worked ?????????
da
Powering off and back on worked for me with this same problem.
da
My camera isn't on nor is my messenger
Punteggio 0
I have the same problem except I can’t take photos or vidoes. And I can’t delete and photos or videos either
Punteggio 0
Mine dose the same thing so u held the power button down and the home button but this did not work
Punteggio 0
Aggiungi la tua risposta
Jeffrey claro sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 38,922
