Can my cracked screen be fixed
Samsung s6 active
Cracked screen but everything else works
Questa è una buona domanda?
Samsung s6 active
The S6 Active inherits most of its hardware components from the Galaxy S6, including an identical octa-core processor, 3 GB of RAM, and a 5.1-inch display. It uses the same display type as the S6, and has a 16 megapixel camera. Its hardware design is similar to the S6, except it is slightly thicker, has metallic rivets, and uses three physical navigation keys instead of a physical home key and capacitive back/menu keys like the S6.
So the repair should be very similar.
Sostituzione Vetro Posteriore del Samsung Galaxy S6
Possibly traci @kaniggit49 or
can tell you if it uses the same glass.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 597
