Salta al contenuto principale
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
152 Domande Visualizza tutte
I removed the 3g module from my ipad 2 3g and wifi.
How can I restore my ipad 2 wifi+3g gsm when I have removed the 3g module. It stops about midway when installing firmware and never finishes with an error (1).
Maybe there is a chance to use it as an ipad wifi only?
Questa è una buona domanda?
Punteggio 1
1 Commento
can you post a photo of the 3g module you removed?
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
No, you will need to put it back.
Unless you replace the CPU and main flash from a wifi iPad so making it a true wifi-only model.
Punteggio 2
2 Commenti:
Maybe you can show the picture , what exactly is to be removed to make it work just Wifi ?
da
Not removed, but replaced using the same part from a wifi only iPad.
The CPU is the chip which has Apple logo and A5 writing on it. The flash memory is the identical 2 large chips. On 16G models one of the spot is left blank.
BGA soldering skills required and replacing these parts can cost more than the device's worth. So it is hopeless.
da
Yes u can use wifi only. But u must try fix logic board. U must terminate Some chip on logic board. And firmware update.
Punteggio 1
Aggiungi la tua risposta
zevaksarturs sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 7
Tutti i Tempi: 275
