Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1687/A1634. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
1041 Domande Visualizza tutte
iPhone 6G Plus battery fit 6S Plus?
Hello,
As title say does a iPhone 6G Plus battery fit 6S Plus? I see they have same connector but can't find a anwser on the internet. If they fit there are any downside in using the 6GP Battery on a 6SP? Asking because i only have 6GP Batteries at the moment and want to replace the 6SP damaged battery.
Thanks
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
3 Risposte
Soluzione Prescelta
No.
iPhone 6 Plus Replacement Battery
Compatibility
All iPhone 6 Plus (Not iPhone 6, 6s, 6s Plus)
iPhone 6 Plus Battery
iPhone 6s Plus Replacement Battery
iPhone 6s Plus Battery
Compatibility
All iPhone 6s Plus Models (Not iPhone 6, 6 Plus, or 6s)
Immagine iPhone 6 Plus Battery
Prodotto
$29.99
Immagine iPhone 6s Plus Battery
Prodotto
$29.99
Punteggio 3
8 Commenti:
Thank you, its all i need :)
da
Can you explain please why it doesn't fit?
da
Won't fit means won't fit, no need to explain.
da
Easy, the batter capacity of the 6S+ is different from the 6+ and will warrant a different power management. Moreover, the battery is not just a dumb reservoir of electrons. It also has a small electronic board that communicates with the phone to tell it how much if a charge it is holding, and the temperature. The capacity is calculated as a %. Having different capacities and a different board altogether means there will be miscommunication between the battery and the iPhone resulting in the iPhone acting out. And the software handling the communication is different for the 6+ and the 6S+..
da
Thank you very much Rany. Your answer was nice.
da
Mostra altri 3 commenti
Risposta Più Utile
Okay, so updated information.
You can use a 6 plus battery on a 6s plus and vice versa.
Not sure why but 6 Plus, 6S, 6S plus and the SE all use the same battery connector.
I have confirmed this using one of those Battery Fast Charging Activation test Fixture tools that charge up iPhone batteries.
Punteggio 4
3 Commenti:
Yes i notice that, still i have to do more force to fit a 6 plus into a 6s plus motherboard connector
da
I have tried put new i6 plus into 6s plus yesterday. Gave it charged to 100% Plugged out in the morning 7.00am Played 3-4 MOBA games (AOV) Checked after the game finished around 8-9am it was 87 % then I was on youtube and chatting until right now commenting is 12.04pm Battery shows 73% So I though this works well but this is just the first day of this new battery. So I don't really know the result for next day. But now I can say that it works pretty well without any lagging or heat just a little warm while in the game ,and that's very normal for high graphic games .
da
6 plus has the larger battery so good call on the battery.
Not sure why the 6s plus has a smaller battery, probably due to the added 3D touch layer making it a requirement to make the battery thinner for safe measure.
da
i can confirm that Iphone 6s battery does work on Iphone 6 Plus
Punteggio 0
Aggiungi la tua risposta
Tiago sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 13
Tutti i Tempi: 10,986
