Salta al contenuto principale
Released in 2013 Model number: ONETOUCH 7024W FCC ID: RAD386
Accidental recovery mode when trying to turn it on
My alcatel one touch fierce power button completely broke a while ago so I had to turn it on my holding down the up volume button and plug in a charger and wake it up with the sensor on the phone. This morning I was turning it on and accidentally chose "Recovery Mode" instead of "Normal Boot" on the menu. The phone is stuck on the recovery mode menu and will not get off of it, even when I run the phone out of battery and try the up volume+plug in. Is there any way I can get off the the recovery mode menu
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
I have fixed my problem, I took off the both back plates and put some metal in the power button slot where is snapped, it made the phone restart and get out of the recovery mode.
Punteggio 1
If your recovery supports adb then connect to pc and adb reboot.(if you did not flash a custom recovery like TWRP or 4ext then your recovery does not have adb.
If your recovery does not have adb then just disconnect and reconnect battery by using the ifixit guides.
Punteggio 0
1 Commento:
This didn't work, even when I disconnect and reconnect the battery it goes right back to the recovery screen.
da
Aggiungi la tua risposta
mrfatguy227 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,153
