Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
iTunes 1671 error and lines on screen
Hi after display replacement everything went good, but after few days screen went red. I did dfu but it shows me 1671 error and white lines on screen. I tried to replace everything(battery, display, charging port). PLEASE HELP ME. I tried to restore on 2 PC.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
https://www.youtube.com/watch?v=NEsP_fwi...
Punteggio 0
5 Commenti:
this should fix your problem
da
This way it shows me 2009 error.... any ideas ? Maybe try to restore on mac ?
da
yes try to restore on your mac
da
in my experience all apple devises very picky about what cables it will restore with. Error 9 is almost always related to the cable, NOT the dock connector/flex cable. Use the official Apple cable if you still have it, or borrow one from a friend.
If that doesn't work, it might also have something to do with the IPSW you are trying to restore with. Try using a different IPSW or using redsn0w to boot pwned dfu mode and restore like that. It could be this because of the error can be related to the ramdisk kernel rejecting the ASR because it is not signed properly, thus breaking the connection with the device and causing the error
da
How error 1671 iTunes can be fixed?
In order to fix this problem you have to follow the steps mentioned below:
The antivirus has to be updated and run the full system scan to make the device free of virus.
In order to make the iTunes compatible the current iOS version or the iDevice that you are using, you have to update it to the latest version.
You should connect your iPhone, iPad or iPod Touch with high-speed USB port.
Your computer should have the latest version of operating system.
In this way you can fix this error.
da
Aggiungi la tua risposta
robinfrolik sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 144
