Salta al contenuto principale
Machine-readable instructions that direct computer processors.
SQL server after RAID problems
We had a SQL server die due to some RAID problems. We sent the machine out to a data recovery company and they are able to recover the .MDF and .LDF files from the drives. Will I be able to use those files to restore the databases to a new machine?
What do I need to watch out for? Thanks!
Questa è una buona domanda?
Punteggio 1
1 Commento
You've been very kind in your efforts to help. Thanks for that. Solved!
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Have u tried out the old way of creating empty database with same name.
Stop sql server
Paste database at the same location ...
And restart the server ....
Does it helping u out .....
If that doesn't help, then the only thing I can advise is to try to restore database using SQL Server Recovery Toolbox. All the details about this program can be found at the link. http://www.oemailrecovery.com/sql_repair...
Punteggio 1
1 Commento:
May be this article will give you more information.
http://www.techrepublic.com/forums/quest...
da
Aggiungi la tua risposta
DanielNetrval sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 699
