Salta al contenuto principale
The sixth-generation Honda Civic was introduced in 1995. It retained its class-leading handling as it, along with the fourth and fifth generations, had front double wishbone suspension, the advanced independent suspension inspired by Honda's racing research.
52 Domande Visualizza tutte
while accelerating my rpms rev up n down why
My 2000 honda civic hx while accelerating my rpms rev up n down why
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
This does occur if you have an automatic transmission and it is shifting gears.
Punteggio 2
This can also happen with a manual transmission and a worn clutch (slipping). You'll have to provide more information for a diagnosis. What engine is in the car? What type of transmission? Has any work been done recently? Is the problem random, or does it happen under certain circumstances? With some more information, we'd be happy to help.
Punteggio 0
4 Commenti:
1.6engine CVT transmission not random this goes on every time I go please help me figure out problem
da
It sounds like it is something slipping inside the transmission. I'm afraid you'll need to find a good mechanic and have them look at it.
da
Chrysler econo Mode?
da
CVT does not shift gears so the RPMs should not go up and down, you marked the answer as good???
da
Aggiungi la tua risposta
nicole sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 523
