Salta al contenuto principale
Repair guides and support for the Expedition, a full-size SUV based on Ford's F-150 pickup truck. Closely related to the Lincoln Navigator.
51 Domande Visualizza tutte
Accessory lights won't go off
Interior lights won't go off on my 1997 expedition
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Check the switch that turns the dash lights brighter and dimmer. There is usually a position on the switch that when turned to the brightest setting on your dash lights can be turned a little more which causes the interior lights to stay on. You will feel a click in the switch at the point the interior lights will come on.
Good luck.
Punteggio 0
Tried that ! No luck
Punteggio 0
Check the door switches. It might be that one of them is broken or has a loose connection.
Punteggio 0
Aggiungi la tua risposta
Ray Belluomini sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 453
