Salta al contenuto principale
Bricked Phone help me bring it back Alive
please guys anyone help me !
what can i do to my phone i was facing some problems with it and my friend tried and failed by loading a wrong boot on it so the phone is worthless right now it's not starting or giving any respond when i connect it to my laptop and i didn't get the chance to use it i only used it for a month .
Please any suggestions or ideas would be appreciated
Questa è una buona domanda?
Punteggio 1
2 Commenti:
i'm using a converter because in my country we don't have the proper cable
da
Hi, how is everyone doing? I also bricked my device. It's also not able to go into fastboot. It's a moto G X1032, and android 5.1 was installed on it before flashing. I tried using file from this link https://forum.xda-developers.com/moto-g/... to revive it but it failed. please help, thanks.
da
Aggiungi un commento
2 Risposte
You likely just need to reflash the factory images. Just boot into fastboot by holding volume down and power, and flash the factory image from here: https://developers.google.com/android/ne...
If your phone shows QHSUSB_BULK in device manager, it is much more complicated. It seems that there is no unbrick method for the 5X currently if you are stuck in that mode.
Punteggio 0
10 Commenti:
i pressed volume down and the power button put it didn't do anything
da
Plug the phone into the computer, what do you see in device manager?
da
it says unknown USB Device
da
Can we get a screenshot? Also what cable are you using.
da
da
Mostra 5 altri commenti
So, what was the final chapter? Could you turn it on? I have this issue: sending sparse 'system' (524289 KB)... FAILED (too many links)
Punteggio 0
1 Commento:
try a different usb port
da
Aggiungi la tua risposta
Mostafa Heikal sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 8
Ultimi 30 giorni: 33
Tutti i Tempi: 5,899
