Salta al contenuto principale
Modello A1418 / Fine 2012 / Processore Core i5 da 2,7 e 2,9 GHz o Core i7 da 3,1 GHz
212 Domande Visualizza tutte
Installed new SSHD. Error Code 4sns/1/40000000:th00-9.000
I installed a new SSHD after replacing the older HHD that had a SATA failure. When I rebooted with the new drive and ran a diagnostic hardware test, I get an error code 4sns/1/40000000:th00-9.000.
I have been searching for a solution and have found a thermal sensor adapter on OWC and others have done a software workaround for fan speed.
Any suggestions out there?
Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Lets back up here... You stated the system had a SATA failure can you expand on what you mean here. Often this implies the system logic board is having a problem, not the drive.
The 21.5" models don't require the in-line thermal sensor hardware the 3.5" drive require as they use 2.5" drives. I don't recommend software solutions to over-ride the systems thermal management as we have found they make things worse in the long haul which are more costly.
Punteggio 2
Aggiungi la tua risposta
Justin Calpito sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,553
