Could I wire a video input into a CoolPix 1000 pj?
I got a CoolPix 1000 pj with water damage but the projector works on it. I was wondering if it would be possible to wire a video input into the projector? Any ideas?
Questa è una buona domanda?
If the unit still projects well from an SD card, I suggest you just use it as a projector and not try to modify it.
If you are very good with small tools and can put things back together, you might try taking it apart and trying to clean up the focus and shutter mechanism, and of course, get the residue off the lens and (carefully) off the CD sensor itself. You probably won't make it much worse, but you could kill the projector part if you make a mistake.
Good luck!
LCM
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,127
1 Commento
This question was migrated from http://meta.ifixit.com/.
da iRobot
