Salta al contenuto principale
Model No. A1367 / 8, 16, 32, or 64 GB capacity
How to remove glue from under the motherboards shield
I am replacing a screen on my ipod touch 4th generation and the guy who refurbished it before glued the shield to the motherboard if you could help me i would very much appreciate it,
Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Is it actually glue, or is it just really sticky adhesive tape?
Punteggio 1
2 Commenti:
By default there is adhesive sticking behind the metal shield above the motherboard. They come like that. It's just really sticky adhesive tape.
da
How do you get that up
da
I dont know all i know is it will not come up
Punteggio 0
6 Commenti:
The process I use involves a variable temp heat gun set at anywhere from 180-200 degrees to help loosen the adhesive and slowly work the shield up using a ESD safe plastic like spudger to help seperate the two. It take a bit of work an patience but it will come loose.
da
Will a hairdryer work too
da
That will help loosen the adhesive but may require more time with applying heat whereas I do not believe hair dryers reach the temps necessary for what is required. If it is all you have available though it is absolutely worth a shot.
da
Because if you used a heat gun for too long wouldnt it melt the motherboard or at least damage it
da
As long as it is set between 180-200 it will be okay. I wouldn't leave it blowing on it directly for a extended period of time, but enough till you feel the adhesive loosen. I personally use a custom made hot plate that is set in that range for all my device repairs that have the screens adhered on. If monitored and done correctly and cautiously, the device will be perfectly fine.
da
Mostra 1 altro commento
Aggiungi la tua risposta
Jimmy Robertson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 180
