Salta al contenuto principale
The Visual Land Prestige Elite 8Q is an 8-inch Android tablet produced by Visual Land.
My Tablet is Stuck on a Black Screen
As the title says, my tablet is stuck on a nonfunctional black page with only the back button and taskbar. (It's similar to the lock screen.) I know it is not just my lock screen due to the fact that my taskbar is functional whereas on the lock screen it is not. I also have noticed that my tablet is working in the background. When the screen is powered on, I catch a glimpse of what app is open for an 8th of a second but then back to the black screen. I have tried rebooting several times (including safe mode) and I even called Visual Land Support. The only solution offered was factory reset. I have used all 11 GB so that's not really an option for me. I was hoping you smart people of the Internet could assist me with my serious problem. Thank you very much, and have a great day.
Update (07/13/2016)
The tablet was not having an internal problem. Apparently, a micro SD card I had inserted caused the tablet to malfunction. I'm not sure how something like this is possible, but it is fully functional as of now. If someone else is having this same problem with their device, I recommend first powering down the device, taking the card out, then powering the device back on. This should fix the problem if you have the exact factors of my issue.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Dear friend,
i had read your issue, the exact solution is reset,
but you can just try to remove battery connection to the board ( then keep it disconnected for at least 30 minutes) then reconnect then turn on it..
good luck my friend
Punteggio 2
3 Commenti:
And by reset you mean hard reset, correct?
da
yeah, if hard reset not fix, you need to flash firmware,
da
Flash firmware? How do i do that?
da
Aggiungi la tua risposta
Protomon sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,151
