Salta al contenuto principale
Guide per la versione Wi-Fi dell'iPad Mini 2. Annunciato il 22 ottobre e introdotto il 12 novembre 2013. L'iPad mini 2, noto anche come iPad mini con Retina Display, ha tutti i pixel dell'iPad Air in un più piccolo fattore di forma da 7,9"
Back-light fuse pops as soon as the battery is connected.
I received an iPad with a back light issue. usually i would pin it down to the fuse/filter. but every time the fuse is replaced i see a puff of smoke come from it as soon as the battery is connected. I have additionally replaced the IC/diode and the coil (I know its not the coil... but still). has anyone else encountered this if so is there a solution.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Check the camera IC's. I had a heck of a problem with iPad Mini 1st gens popping filters and it ended up being a bad camera IC. I was popping them when I disconnected the screen and didn't figure it out until it was too late.
Punteggio 0
1 Commento:
hmm ok. i will check if i can find the camera ic. although i can't see how the back-light would be connected to the camera.
da
Aggiungi la tua risposta
Thomas Edwards sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 103
