The black wide ribbon cable between the sub and main board
That cable you remove in thus tutorial between the sub and main board below the fams what is it called what is its part number and where can i buy it? thanks.
Questa è una buona domanda?
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 282
I would like to know as well, however in English. I could not find the part using the search words below, however, very much appreciate the answer. I was increasing the size of the hard drive (128GB SSD) to a 1TB, during the process the bios screen came up and then something happened and now no display whatsoever, even if connected to another monitor through HDMI. My thinking is maybe I damaged the small bundle of cables above the three screws (top right hand corner) that lead to the screen. I need to buy this wiring harness? replacement part but don't know what to call it and or what the part number would be or where to buy it? Thank you, any help would be greatly appreciated! Its a great PC, however, is now essentially worthless.
da David Paladin
