Salta al contenuto principale
The Tegra Note 7 is made by Nvidia and branded by graphics firm EVGA. This device is known as the EVGA Tegra Note 7 in the United States, Cherry Mobile Tegra Note 7 in the Philippines, Advent Vega Tegra Note 7 in the United Kingdom, Gigabyte Tegra Note 7 in Australia and New Zealand, Gradiente Tegra Note 7 in Brazil, Gazer Tegra Note 7 in Ukraine and Russia, and XOLO PLAY Tegra Note 7 in India.
TN7 stock battery replacement
Hello experts, the battery performance of my TN7 has gone really worse that I have to charge it at least thrice a day.I wish to switch the stock battery with a bigger one but don't have enough technical information about this. So anyone aware of this,be generous enough to share the info.By the way,thanks in advance.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
@noufi "has gone really worse" is most likely a battery issue. In the case of your tablet replace the battery with a new one. There are no larger replacement out there. Check your setting and background apps and ensure that you run the latest OS version on it.
Punteggio 1
Aggiungi la tua risposta
Noufal sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 3
Ultimi 30 giorni: 22
Tutti i Tempi: 1,195
