Salta al contenuto principale
Repair guides for Windows cell phones manufactured by Nokia.
How To fix Lumia 735 SD Card errors...
Drop my Lumia 735 several times and start showing SD card errors, looking all over the web and replacing SD card just wouldn't works ...
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Finally I decided to open it up. You need a torx screw driver and a plastic tab. To take apart the Nokia Lumia 735, just follow the video instructions here https://www.youtube.com/watch?v=yLCwTk4D....
The culprit is the ribbon cable connection. Just take apart the phone and reseat the ribbon cable connector tightly between the front screen assembly and the back cpu assembly will solve the problem.
Apparently every time you drop the phone, it loosen the connection lightly. after several drop, the SD Card error show up and asked you to fix bit it will never work. Swapping card wouldn't work ether.
Hope this help everyone that encounter similar problem : )
Punteggio 0
Aggiungi la tua risposta
Burney Poh sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 680
