Salta al contenuto principale
Solutions to fix common problems with the Durofix RV332 Cordless Li-ion Screwdriver.
7 Domande Visualizza tutte
What is the polarity of this screwdriver and positive or negative
what is the polarity of this screw driver...a positive or negative...lost the adapter and purchase a universal ac adapter...butI need the polarity inorder to recharge...can you help????
Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
While there is a 90% chance that the outer sleeve is negative, to be sure you might go on Amazon and ask the question of one of the reviewers that bought an adapter for it. If they have a volt meter they can tell you.
https://www.amazon.com/Durofix-10730378-...
Punteggio 1
Got one at an estate sale and took a chance charging it with positive tip and it worked. I used 4.5 vdc @ 500 mah with positive tip and it took about an hour.
Punteggio 1
Aggiungi la tua risposta
sunnie1948 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 689
