Salta al contenuto principale
The Dyson AM07 is a bladeless tower fan released in 2014. The AM07 uses "Air Multiplier" technology to create a smooth stream of air without using visible blades.
19 Domande Visualizza tutte
Fan is not turning on - have tried different outlets, no luck.
Have plugged fan into different outlets, changed remote battery - nothing. Is there a fuse that can be replaced and if so where do I purchase and how do I replace it?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
There is one timed fuse on the main PCB, but if the fan is not powering up at all, and you can hear a very faint noise coming from the base (high pitched whistling noise), then the problem may very well be the main PCB. The chip on it has a tendency to break down if the fan is not cleaned out regularly and the main plug top fuse is up rated.
Punteggio 0
Aggiungi la tua risposta
corgimom48 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,630
