Salta al contenuto principale
1.7 GHz dual-core Intel Processor (Turbo Boost up to 2.6 GHz) with 3 MB shared L3 cache
139 Domande Visualizza tutte
Trackpad not working: swollen battery or bad trackpad?
Hi All,
The Trackpad on my mid-2012 11" MacBook Air stopped working. The battery doesn't seem to be losing power. Other than opening up the computer and looking for swelling in the battery is there any easy way to diagnose the cause (i.e., is it a bad trackpad or a bad battery?). I'm hoping to order the right part (trackpad or new battery) before I open the computer up.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
4 Risposte
Risposta Più Utile
Well this is a no brainer, open it up and look, don’t guess.
MacBook Air 11" Mid 2012 Lower Case Replacement
Punteggio 2
Hi
I would buy a new track pad!
then the battery .
It could also be a dodgy ribbon?
Ray
Punteggio 1
2 Commenti:
Thanks Ray. The pad won't actually click, so I'm guessing it's more likely the pad itself rather than the ribbon. I'm going to try the new pad first and see what happens...
da
check out the battery first. it has a half life, goes bad well before the trackpad.
da
Does the trackpad have less travel, or a less clear and crisp click? If so, I would go the battery route first. If it does not show these symptoms or just doesn't work at all, take it to an apple store. It is probably the trackpad itself. This can be replaced at home but a trackpad issue could be many different things, so I would take it to an apple store first.
Punteggio 1
This worked as first aid, now I have time to look around for a replacement battery.
These are spacers (hair elastics) at the near corners of the trackpad to bend the battery out of the way of the trackpad.
Additionally, I left the middle battery retaining screw loose, about 1.5 turns, to allow the battery to bend.
Punteggio 1
Aggiungi la tua risposta
Grant Kester sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,726
