Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
LCD flickers and vertical lines
Hi guys,
my iPhone 6 recently displays vertical lines all over the screen, and I can't see anything from the OS, as the background behind the vertical lines is sometimes white and sometimes black. The lcd simply flickers and the lines jump around like crazy :)
Thought it's the LCD but even after changing the screen the same problem persists.
Everything else seems to work as intended as it vibrates on startup and also vibrates when the mute switch is activated.
I'm not sure if it connected with water as my GF was using it when the problem showed up but the LCI doesn't indicate any water damage.
Any ideas what else could cause this problem?
Thanks in advance guys
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Try to clean connectors. Usually after water damage there is a limescale on motherboard and connectors. You need to disassembly logic board and clean it in isopropyl alcohol. Do the same with connectors on LCD flex.
Punteggio 0
1 Commento:
thanks for your answer, I will buy isopropyl alcohol and give it a try
da
Aggiungi la tua risposta
12dollar sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 280
