Salta al contenuto principale
Repair and device guides for the 2016 Samsung Galaxy J5 smartphone, model SM-J510FN.
Pc cannot detect my phone(Samsung Galaxy J5)
Hi.. When i connect my phone to the PC he cannot detect my phone.. I want to transfer files and music..
Questa è una buona domanda?
Punteggio 24
5 Commenti
can you check the drivers first.
da
But I want to root my phone which is only possible when usb is connected
da
my mobile samsung j5pro rotates 360 ani i have problem in usb too............
da
I cured mine, the PC did not recognise the J5, I had been using leads that worked on other devices, so I used the genuine lead that came with the phone and it was the end of the problem.
da
Thanks Peter Main.
It had me completely baffled. Tried your idea, and it worked straight away.
John Walsh
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi, have you checked debugging? Tap "Settings" on your Samsung, find "Developer Options" and then click on "USB debugging".
If your PC still cannot detect it, you can try an app that connects your phone to PC wirelessly, for example, AirMore. Below is a video about how it works.
You can also use it to transfer files from Android to PC.
It is a free app and takes up little storage space. You can have a try!
Punteggio 6
5 Commenti:
THANKS !! It was helpful !!! It works ! <3
da
my mobile samsung j5 is curcut is me mera all deta pices videos hen wo mujy chayean
da
curcut short no on my mobile
da
Well i try download original driver after it was working correctly so i download the original driver and then it stopped working on my windows 8.1 so its the windows actually it also dismantlet couple other devices ........ anyway without counting my other little notebook pc can open it and windows 8 is saying my device is the problem but i know is the windows :D xD so if u dont want issues go on win 7 not 8 and 10 ima reinstall it in couple days xD
da
Aggiungi la tua risposta
AngelN sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 23
Tutti i Tempi: 66,383
