Salta al contenuto principale
Huawei Ascend G510 Android smartphone. Announced 2013.
12 Domande Visualizza tutte
Why is my phone screen black after it got wet?
Im sorry for my bed English. My phone got wet after dropping it in toilet. Took apart and wipe it then i but it back and my screen just went crazy, there was purple lines and black screen , so i again took it apart and after i put it back it didnt work, and it looked like there was moisture on screen so i took my hairdryer and dry it, still didnt work.That was a month ago, now when i turn on i hear a sound that mt phone its switch on but its black screen.Can i do anything to fix it?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Risposta Più Utile
it sounds like you definitely blew the LCD. but the fact that you took out a hairdryer could have done a lot more damage.
Replacing the screen may help, but with water damage the problems it can cause can be endless. you can take the risk if you like, but there is no guarantee it will work.
Most reputable repair shops that specialize in micro soldering would be able to help you, but the price of repairing it may be more than the phone is worth. It's up to you if you want to spend that amount of money.
If there is data on the phone that you need recovered though then they should be able to help you out with that too
Punteggio 1
Thank you for you answer!
Punteggio 0
esto sucede porque el conector de la pantalla perdio pistas por eso da pantalla oscura o pantalla
blanca
Punteggio 0
Aggiungi la tua risposta
Marla Durden sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,442
