Is the touch problem in y6 pro software problem or hardware?
The touch in y6 pro is veeeeeery bad is it hardware problem or software problem?
Questa è una buona domanda?
Enable the developer options by clicking 7-10 consecutive times on the kernel version in your "settings - about phone".
Then open the developer options - animation "off" - transition "off".. It won't secure your problem permanently but it will do for a period of time.. Note* keep your internal memory below 50% used space or else you will face some buggy software instability..
Cheers ;)
Protect ur screen from dirt. Keep dry then touch will be ok
Follow these steps, it worked for me ;)
1. Try to remove the cover.
2. Disable "Show correction suggestions"
3. Disable "Personilzed suggestions"
I have this model, I did every software solution to solve this but no change, so it's a hardware problem
hi my friend i did 3 steps
1. i turned off all if settings in my keyboard like suggestion
2. i did the above result “Then open the developer options - animation "off" - transition "off". “
3. I got the result and now I can type without any problem
and what happen to this phone I want to tell you about this phone I think this phone when want to use ram and CPU in its system cant type well so you should decrease the usage of ram and cpu in conclusion you turn off every related thing to keyborad and now you have a good key board thats it
thanks
Hard ware problem it touch screen broken
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 12
Tutti i Tempi: 10,720
