Salta al contenuto principale
Guides for the Wi-Fi version of the iPad Mini 3 (A1599). Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
20 Domande Visualizza tutte
Is the charge port on an iPad mini 3 replaceable?
Is it possible to change the charging port on an iPad mini 3? The steps in the disassembly process and it looks like it is tied to the motherboard...I don't want to take the whole thing apart if its not possible.
Thanks in advance!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Yes the charging port can be replace but it's soldered to the motherboard. so you will need soldering skills to do the repair. The charging ports very seldom goes bad, so unless you have damage to the charging port it may not be the charging port giving your problem, but a chip on the motherboard.
Punteggio 0
Aggiungi la tua risposta
vbgagnon sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,043
