Salta al contenuto principale
Repair guides and support for motorcycles manufactured by Harley-Davidson.
77 Domande Visualizza tutte
Why is my front right Indicator not working,bulb ok
I have a XL1200 Harley Davidson Sportster 2012
It came on yesterday 9/6/2016 as i was turning right,then suddenly went out and on dashboard little green arrow flashing rapid?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Check the rear bulb as well when one goes the other acts weird so check to see if the rear bulb is bad
Punteggio 2
1 Commento:
Thanks Jim i will check rear indicator just in case that is the fault.:)
da
Risposta Più Utile
Sam "little green arrow flashing rapid" is caused by the indicator not working. Make sure that the bulb is indeed okay, I'd replace it anyway. If a new bulb is not working as well, check the wiring going to the indicator. Make sure that it shows continuity.
Punteggio 2
1 Commento:
Funny enough the indicator decided to work in the rain,touch wood its still working now,but i will check back indicator like you said,thanks oldturkey :)
da
Aggiungi la tua risposta
SMUDGER sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,554
