Salta al contenuto principale
The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
60 Domande Visualizza tutte
Mother Board ASUS X550L
I have a Asus X550L which is not functioning anymore due to short circuit as what the technician said, the problem was its on board power chip which they said they have to replace the entire mother board which is cost a lot.
so does anyone can share a diagram of this or anyone knows the exact details on that
power chip because now a days Im sure we can search or order it online..
please help thanks..
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi Sheldon,
This link shows the input unit of a laptop motherboard (DC jacket, capacitor, etc.). It might help you to localize where the power IC is on your motherboard.
There might be a diagram available for your laptop here. However, you also need to have the program to view the file.
I hope this helps.
Steffen
Punteggio 1
1 Commento:
thanks ill go look for a program to open the file..
da
Aggiungi la tua risposta
Sheldon Semblante sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,700
