Salta al contenuto principale
Processore dual core Intel Core i5 da 2,5 GHz (3,1 GHz con Turbo Boost) con 3 MB di cache L3.
265 Domande Visualizza tutte
Burnt Component Near LCD Connector
Got two faulty parts: Fuse and Resistor??
I have found the fuse (0402-HF SMD fuse) but not sure if the other is a resistor or what. Any ideas? At first, no display so I bridged the fuse. Now Im getting a solid grey screen so I assume this burnt part would solve it?
First image is mine with bridged fuse and burnt part. Second image came from the internet.
Red: Bridged Fuse
Yellow: burnt part. what is that?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
@sylar the part in the yellow circle is neither a resistor nor a capacitor. That is reference designator L9004 which is a 120ohm 1.5A inductor in a 0402 package. As for your fuse, it is never a good idea to bridge it that way since you are now having an unfused circuit and could run into multiple issues with that later on.
Punteggio 3
3 Commenti:
Thanks. I know bridging any fuse is bad but In this case I had to, to know what's really going on. Looking on the metal cover, of the MBP, it was bent and the case was touching the components... somehow. But I'm confident replacing both parts should do. Parts now ordered and will confirm. Many thanks.
da
Hi @oldturkey03 , do you happen to have the schematics for this laptop? I cant trace where the L9004 should soldered onto.
da
To add, MBP now works.
da
Those components are either a resistor or a capacitor depending on the circuitry. You would need the Schematic's to determine exactly which. As for bypassing a fuse as you say you did that was a bad idea since turning the unit on could very well fry even more circuits. Worse you wouldn't even know which ones were now bad also. Replacing the selected parts on your circuit board will also require special soldering equipment and 3M Soldering training. You would be better off getting a replacement board.
Punteggio 1
1 Commento:
Im technical so replacing any part here will be a breeze.
da
Aggiungi la tua risposta
Sylar sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 9
Tutti i Tempi: 698
