Salta al contenuto principale
Thin, light and powerful with incredible sound and Wi-Fi capabilities is what everyone needs to have on the go.
45 Domande Visualizza tutte
How can I fix the antena of the NIC from a laptop?
Hello,
While i tried to fix some problems of a laptop, accidentally I broke the antenna of the NIC. The wire and the gold prong just broke off. I tried to reconnect putting the wire inside the gold prong and it seems right but, after that, the WiFi Signal is too weak. How can I fix this problem? There is some way to reconnect the gold prong and the wire?
Thanks!
Questa è una buona domanda?
Punteggio 1
2 Commenti
Please give us the make and model of your system.
You likely will need a replacement antenna cable. But without knowing who's system you have here I can't offer you more. Posting a good picture might be helpful as well.
da
Asus UX303L. The only way is replacement? Can´t I tin solder wire?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Sadly this is a special coaxial wire which is crimped at the factory so you can't solder it back on.
Here's an engineers product guide for them: Micro Coaxial Connectors for WiFi & Bluetooth antennas.
You might be able to get a few samples from someone and very carefully put on a new connector. Just make sure you measure the one you have so you get the correct one.
Punteggio 3
Aggiungi la tua risposta
Ramon Paris sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 576
