Salta al contenuto principale
Annunciato il 16 ottobre 2014, identificabile dal numero di modello A1347 e EMC 2840.
15 mm HDD in Mac Mini Late 2014?
Hi everyone!
Is it possible to fit a 15 mm HDD in Mac Mini Late 2014?
Specifically Seagate ST4000LM016 http://www.seagate.com/gb/en/products/la....
Default HDD is 9.5 mm and all the tear downs (incl. videos) I've seen do not focus on the free space you have below HDD enough.
Thank you!
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
While Apple did reconfigure the drive frame so the HD bay is larger in the newer Blade SSD/HD models. Apple so far has only used the smaller 9.5 mm 1 TB drive in their drive offerings.
With that said, I don't see any reason why the larger 15 mm drive wouldn't work here (it will be tight!) If you haven't bought the system yet I would recommend getting the SSD model and then buy the dual drive kit to add the HD. Getting the SSD later will be harder & more expensive.
I've also been toying with the idea of upgrading my home mini (2012) which has dual 2 TB drives (media server) to this exact configuration. :-}
Let us know how it goes!
Punteggio 2
2 Commenti:
@danj thank you for the response.
Already have the Mini with PCI-E SSD and SATA cable.
It's very unlikely I'd buy 15 mm before knowing for sure it fits in. I'll wait for an answer for some time in a hope someone is tearing down his Mini right now. :/ And then probably fall back on 7-9.5 mm 2 TB.
da
What you could do is take some foam board to cover the top of your current HD to make it 15 mm so you can see if it would fit. I suspect you'll need to leave the drive loose to make up the difference. I got 14 mm using a ruler measuring to the top of the frame when I first though I might get a newer system.
da
Aggiungi la tua risposta
an0nym sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,055
