Salta al contenuto principale
Strange smell when running
Hi,
I recieved an ex-display Kenwood KMC560 today. And I tested the speeds with the whisk and water in the bowl. I noticed strange smell when I was changing the speeds. The smell is slightly metalic. I also noticed a bit of oil on the sides. The smell is a bit similar if you run an old motor. Is that normal? If it going to damage the product if I continue to use it?
Thanks in advance.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
This sounds like normal operation for this sort of accessory. Unless you smell something *burning* you likely don't have anything to worry about
Punteggio 2
Aggiungi la tua risposta
Alexander sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 583
