Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Where is the noise cancellation mic located? Too much background noise
Hi there,
Have a customer who is having issues with hearing too much ambient/background noise after having their screen repaired. Can anyone tell me where the noise cancellation microphone is located so I can check out if that part needs to be replaced?
Thanks!
Questa è una buona domanda?
Punteggio 1
1 Commento
I am having the same issue. Cannot use the iphone as handsfree in the car because of too much background noise.
da
Aggiungi un commento
3 Risposte
Risposta Più Utile
It uses the back cam mic and the bottom Mic...
Punteggio 1
There is also a third mic on the front camera sensor flex that could have been misplaced or damaged during the screen repair.
Punteggio 1
The mic's are located on the bottom of the phone, and on the back of the phone next to the camera. (There is a pinhole).
Also in the iPhone go to Settings --> General --> Accessibility.
Make sure Phone Noise Cancellation is turned ON.
Punteggio 0
Aggiungi la tua risposta
Paul sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 7
Tutti i Tempi: 7,078
