Salta al contenuto principale
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Domande Visualizza tutte
Is it possible to use my MacBook just as a "tower"
I would like to setup my macbook to use just the system, keeping the lid closed, external monitor, wireless mouse/keyboard. Is this possible? Due to my lack of knowledge with Apple/Mac Specific cables, will the thunderbolt cable work with my macbook, to which i would go from thunderbolt to hdmi... Or is it not a thunderbolt but a different type of cable?
Questa è una buona domanda?
Punteggio 0
1 Commento
I suspect you really have a MacBook not a MacBook Pro here. Apple didn't make a Unibody MacBook Pro in 2008 only the MacBook.
Here is the full specs of your system: MacBook 2.4 GHz Core 2 Duo" (Unibody)
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
If it looks like a thunder port but is not it is probably a mini-display port. See this so you can tell the difference: http://www.cnet.com/news/confusing-mini-...
If that is the case you would need an adapter like this to get to HDMI: http://www.newegg.com/Product/Product.as...
Punteggio 5
1 Commento:
thanks very much for the info
da
You have to get a thunderbolt to hdmi adapter. The connect the hdmi wire into an external monitor.
Punteggio 1
3 Commenti:
Ive read somewhere that thunderbolt wasnt used in the late 08 model macbook
is that true?
da
https://support.apple.com/en-us/HT204154
Scroll down to number 4 to see if your model is compatible
da
If this is a MacBook system it has a DisplayPort not Thunderbolt connecter (they both look alike). Note the symbol on it if it has a square with two lines it has a DisplayPort, if it has a lightning bolt it has a Thunderbolt port.
da
Aggiungi la tua risposta
vgtalotta sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 408
