Salta al contenuto principale
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459 Domande Visualizza tutte
No power due to battery?
When I have my battery inserted correctly like this:
the phone doesn't turn on at all.
When I have it like this:
it turns on and works with no problem.
I tried with a diffrent board and it does the same, is it a battery problem?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
if you tried a diffrent board, why don't try a diffrent battery ? I think it will fix your problem
Punteggio 1
Risposta Più Utile
Clean the battery gold points with isopropyl alcohol. Make sure it's at least 90% alcohol. Also clean the 4 golden connection prongs on the phone as well.
If that doesn't help try another battery like @cornelis said.
Punteggio 2
Aggiungi la tua risposta
George sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 83
