Salta al contenuto principale
Rockchip Quad-Core RK3288C Processor, 11.6" 16:9 HD (1366x768), 16GB eMMC, Integrated Rockchip® Mali T764, LPDDR3 MHz SDRAM, OnBoard Memory 2 GB / 4 GB
18 Domande Visualizza tutte
It turns on OK but the screen remains white.
The laptop turns on as normal but the screen is white and I am unable to do anything with it. If you tilt it, you can see that the left half of the screen has very light blue vertical lines, in different shades / sizes and patterns. My dog 'may' have stepped on the closed lap tap. Could the pressure from the dog damage the screen???
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hey tinazinger,
Yes, It doesn't take much pressure. They usually crack under the black tape that surrounds the actual LCD. They run around $40-$50 on amazon and pretty easy to change. Get the number off the back of the original LCD before ordering to insure that you get the correct one.
Punteggio 1
Aggiungi la tua risposta
tinazinger sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 810
