Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
Why doesnt iTunes let me restore
Hey guys
I recently replaced my iPhone 5's back housing and front panel assembly. The procedure went well, the phone was working after it and everything was fine except for the past couple of weeks I experienced weird battery drains compared to the another iPhone 5 I have laying around (mine could only hold 19hours of standby in airplane mode...).
I read some stuff online and I thought a restore can fix the problem; maybe I have an app running in the background or something.
The restore always stops at Restoring iPhone firmware... then finishes saying that the restore could not be completed error(-1).
Now my phone is not working.... Any suggestions what can be the cause of the problem or what does error(-1) mean? Any way how to fix it?
Note: I replaced the lightning port/speaker/jack assembly, and the battery as well still error -1 plus my front camera never worked, but I could restore the device before and still had this issue.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Error -1 means dead baseband, either due to a power failure or the chip has actually been damaged.
Punteggio 4
Aggiungi la tua risposta
Joseph Tafferner sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 82
