Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Battery problem? (Percentage issue)
I have an iPhone 6 bought in 12/2014 and in March this year started to have some problems related to the percentage of the battery when it is near 20/25%, the phone turns off and says "no battery" but if I try to power on, fifth/sixth attempt later, boot with is 20/25% usually, sometimes the battery jumps from 25% to 10% and stuck on that until the battery really reach 10% when I connect the charger the percentage back to their normal, it all started when I upgraded my iPhone from iOS 9.0.2 to 9.2.1, I tried to clean install iOS 9.3.2 on iTunes but the problem continues ... this can be a problem in the battery or is a bug on iOS? I have less than 500 charge cycles.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
Soluzione Prescelta
It shouldn't be that bad.. But then again Apple likes to do this kind of thing. I got my 6S on release date, and the charging port is already going bad. You could change your battery... I haven't heard anything about the new iOS hurting battery life..
iPhone 6 Battery
Sostituzione batteria iPhone 6
Immagine iPhone 6 Battery
Prodotto
iPhone 6 Battery
$29.99
Punteggio 4
1 Commento:
Battery life is not the problem, the problem is the phone turning off with 20/30%, i think i will try replace my battery, Thanks!
da
found this blog http://www.etradesupply.com/blog/how-to-...
Punteggio 1
1 Commento:
Thought connecting to wifi would auto fix that...
da
You can also try by using an original charger. Keep in mind that when you purchase an iPhone which is not brand new, the charger is not always an original one. So try to purchase an original iPhone charger and things would get better. If this helped you, follow me on IG @like_kyriee and i will follow back.
Regards,
Punteggio 0
Aggiungi la tua risposta
Heitor Scatolin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 4,138
