Salta al contenuto principale
Repair information for the 4th generation iPad. Released November 2, 2012. Model numbers: A1458, A1459, and A1460.
Distorted image after digitizer replacement
My iPad screen cracked and I got a replacement digitizer. Unfortunately after going through the whole process of replacing, I realized that I had left the iPad turned on while replacing the digitizer (i.e. disconnecting and reconnecting LCD, digitizer, and home button). Now, the screen just displays white with a grey line across the screen. I'm positive that everything else still works as it still locks and behaves as expected. Anything I can do before I try to reseat the LCD connectors?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta più utile
Hey there! A grey line across the screen can sometimes be a sign of graphics issues, but the white screen really screams of a poor contact. Unfortunately, I think you'd best crack her back open, after making sure your iPad is off.
Best of luck in your repair!
Punteggio 1
1 Commento:
Hey! I just got around reopening and retightening the cables. I still have a grey line on white background..
da
Your next step is replacing the backlight filter could of been damage during repair since the battery wasn't disconnected during repair. But requires soldering
Punteggio 0
Aggiungi la tua risposta
Edric Choi sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 15
Tutti i Tempi: 182
