Salta al contenuto principale
L' Apple iPhone 5c è stato annunciato il 10 settembre 2013. La riparazione di questo dispositivo è simile ai modelli precedenti e richiede cacciaviti e strumenti vari. Disponibile nelle versioni: GSM o CDMA. In tagli di memoria da 8, 16, 32 GB. E nei colori: bianco, rosa, giallo, blu e verde.
1233 Domande Visualizza tutte
iPhone 5c time issue (time doesn't change)
Hey hopping someone can help, I recently got a iphone 5c that was dead, I replaced the battery and the screen and i got it working again. The problem is the time doesn't set automatically even though the setting is on and when I lock the screen the time stops counting.
Can anyone help?
UPDATE
Hey so I have noticed that the time changes when the battery is charging but stops as soon as the battery is 100%. Could this be a battery issue?
Questa è una buona domanda?
Punteggio 0
5 Commenti
Have you connected it to wifi?
da
yes and I have tried to do it manually
da
My dear friend you need to turn on locations then plug in with itune time will be reset automatically if not then restore your device time and date will be ok if you still getting same problem then put compass ic . thats it job done
da
Hey so I tried what you said still didn't work although now the time works but only if I have the phone connected to my pc
da
my friend you need to change compass ic then micro soldring
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
There is a crystal oscillator (Y2) on the board which can fail which can cause this problem. It's something which can be replaced. Requires micro soldering.
Punteggio 4
3 Commenti:
Would this be a costly repair?
da
Funnily enough this issue I have only seen it happen on iPhone 5C the most common which is weird.
da
Not too costly Dmtech94. You'd need to check with someone in your area.
da
I have the exact same problem as you except that mine crashes my phone when I try to get into date and time
Punteggio 0
Aggiungi la tua risposta
Dmtech94 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,439
