Salta al contenuto principale
Processore dual core Intel Core i5 da 2,5 GHz (3,1 GHz con Turbo Boost) con 3 MB di cache L3.
265 Domande Visualizza tutte
Hardware test shows error "4SNS/1/40000000: IO0R-1.550"
After the kernel_task process started taking up too much CPU(like 500-1000%) and the system hangs, this happens randomly. I ran the AHT and the error shows up
Figured out this is a sensor issue (SNS) but didn't find any resource mentioning the IO0R code.
Does Anyone know what this code refers to?
PS: My camera is also not working says "No video capture devices were found." in System info
Update (05/20/2016)
I think I found the issue. I opened up my macbook for cleaning up (lot of dust). And disconnected the iSight camera cable. Now the Hardware test passes without any error.
Questa è una buona domanda?
Punteggio 1
1 Commento:
sadly apple does not share the information
But SNS is a sensor issue
da
Aggiungi un commento
1 Risposta
It's likely a problem with one of your current sensing resistors on the board. These can be replaced. Requires some micro soldering.
Punteggio 0
2 Commenti:
Thanks for answer. I thought this was current sensor issue but then I read carefully it says IOzeroR not IzerozeroR. Which seem like I/O port issue or something. I'm just guessing here though.
And if micro soldering solution is not in my reach, would this mean a logic board replacement?
da
Not all the time
you could take it to apple and they will most likely tell you whats wrong and give you a quote
you can use this to your advantage as if its something silly that can be replaced with in 5-10 minutes that you are happy to do then you have saved yourself a bit of money
if it comes to a logic board replacement ( highly doubt) apple charge a fair price but you can get it worked on or buy a replacement and do it yourself
da
Aggiungi la tua risposta
goutham sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 523
