Salta al contenuto principale
Released April 2013, model numbers GT-N5100 (3G & Wifi), GT-N5110 (Wifi), and GT-N5120 (3G, 4G/LTE & Wifi)
Why is my tablet keep turning on and off
It turns on and then off and I can't do nothing with it
Questa è una buona domanda?
Punteggio 0
1 Commento
what was done to start the problem ? was it dropped or were you rooting it?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
If the machine was not damaged either by a drop or you trying to root it you can try disconnecting the battery to clear the cache so it gets a clean boot. Here are instructions to disconnecting the battery
Samsung Galaxy Note 8.0 Battery Replacement
if you just disconnect it for 60 sec it will clear the memory and allow a clean boot .Hope this helps
Punteggio 1
Aggiungi la tua risposta
Meghan sharp sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 264
