Salta al contenuto principale
The Dell Venue 8 Pro is an 8-inch tablet released by Dell in January 2014.
16 Domande Visualizza tutte
Domanda Chiusa
Help identify this component. From Dell Venue Pro 8
My screen broke on the Dell Venue Pro 8. Upon opening it this blue component had broken off the right side of the top of the PCB. (see picture)
I think this was broken off while I was taking the screen off so just a word of caution to anyone else opening one of these.
the board has
bellaire mainboard PCB rev 2.1 printed on it but I cannot find anything about it of use.
My guess might be that a 1 axis gyroscopic sensor of some sort as there are 2 of them orientated at right angles between one another.
Any thoughts?
Update (05/08/2016)
I can almost certainly confirm this component does not have to do with the orientation as I am still able to boot and it does rotate as expected.
Still I would like to find out where I can purchase this to re solder onto the board as this one has had it's solder points broken off when it snapped off the board.
Questa è una buona domanda?
Punteggio 0
2 Commenti
On the one that broke off is there and metal bits that you can see from the outside? (It may just be a spacer)
da
ETHREAL1 thanks for your comment. I do not see any metal on the broken piece except for where it was soldered to the board. hopefully you are right and it is just a spacer but you would think they could use a piece of foam or rubber for that.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I believe it is a spacer, if everything still works fine then I would not be concerned, the reason they would use plastic is that it will not flex (and it is cheaper) I would say if you really want to be safe get some super adhesive and glue it back on...
Punteggio 1
1 Commento:
The other side of the motherboard has no trace so I think you are right!
da
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 415
