Salta al contenuto principale
iPhone con schermo da 4" introdotto nel marzo 2016 con specifiche hardware simili a quelle dell'6s. Disponibile in Argento, Oro, Grigio siderale, Oro rosa con 16 o 64 GB. Modelli A1662 e A1723.
1049 Domande Visualizza tutte
Are home buttons from 5S interchangeable with SE?
I watched and read the entire iPhone SE breakdown. They mention several parts' interchangeability but did not cover the home button. Are these parts interchangeable? Can I use a 5S home button in an SE and vice-versa? (Please do not add information concerning their functionality after being switched; I am only concerned about fitment)
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
4 Risposte
Soluzione Prescelta
Kaye's answer was that the home button was not interchangeable, but the link he/she provided said the opposite. It looks like the home buttons are interchangeable, but as with other Touch ID home buttons, will not provide Touch ID functionality. Only the original home button on a Touch ID device will work 100%, but these will still click and perform the other home button functions.
Punteggio 0
1 Commento:
yes u can iphone se and 5s are compatible its work for me butt u wont have ability to set tuch id
da
Risposta Più Utile
You can look at the APN printed on the cable, they are exactly the same.
Punteggio 3
2 Commenti:
Thanks, Tom. I don't currently have an iPhone SE at my disposal - did you look at part numbers listed on this site or did you compare part numbers in person with actual examples?
da
Well you can check the teardown pics. On the 5s, the APN is 821-2092-01, while on the SE, it's 821-2092-A. The first seven digits are the same. The difference at the end could indicate different colors or part vendors, but the part itself should be compatible.
da
Just tried 5S home button on an SE. Yes, it works.
Punteggio 0
do not think it worked. this blog you can have a look http://www.etradesupply.com/blog/iphone-...
Punteggio -1
3 Commenti:
According to the link, it does work. Most repair techs know that only the original home button in a Touch ID device can be used for Touch ID - replacement parts only need to have the click functionality, and this does!
da
i‘m sorry, you're right, i mean it still features the click functionality but not the touch id.
da
No worries; thanks for the link!
da
Aggiungi la tua risposta
Ryan Alexander sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 35
Tutti i Tempi: 7,063
