Salta al contenuto principale
Processore quad core Intel Core i7 da 2,2 GHz (3,4 GHz con Turbo boost), 2,5 GHz (fino a 3,7 GHz con Turbo boost) o 2,8 GHz (fino a 4,0 GHz con Turbo boost) con 6 MB di cache L3 condivisa.
774 Domande Visualizza tutte
Domanda Chiusa
Is that problem with anti-glare layer on Retina screens still there?
Hello everybody!
I'm planning to buy a Macbook Pro 15'' (2015) MJLT2. But after I made a research about it I found a lot of negative responses about a problem with an anti-glare layers. It seems that this issue is peculiar to MBPr's from 2012 to 2014.
Some guys even created a website to show Apple how global that problem is:
http://www.staingate.org/
So my question is: Is that problem with anti-glare layer on Retina screens still there, for Macbook Pro Retina (2015)? Or is it solved in the newest Macbooks, starting from 2015?
I would appreciate any help or tips. Thank you all in advance! :)
Best regards, Optimix
Questa è una buona domanda?
Punteggio 0
2 Commenti
I wonder if a tempered glass screen protector would alleviate this issue.
da
Thank you for the answer :)
Hmmm... maybe it's a good idea. Guys, anyone used some kind of slass protectors on Retina displays?
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
short answer yes the problem is still around on 2015 models but apple are offering a free replacement screen on all affected models as long as it has been reported to apple within 3 years of purchase.
Punteggio 1
2 Commenti:
Thank you for a prompt answer!
As I heared this Quality program from Apple will end on October, 2016. And it would be really bad to stuck with this problem in 6-7 months of using the Macbook Pro.
Darn... After your words I really don't know if it's a good idea of buying a Pro version :(
da
i would suggest contacting apple about the quality program as it shouldn't end so soon
but if you are buying new you should not get a faulty laptop as apple will have hopefully removed the faulty screen from production.
da
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 5
Tutti i Tempi: 870
